Bent the outboard ends of HS-810 and HS-814. Created the relieve holes in the front spar and bent it. Dimpeld the 4 center holes of the spar and countersunk the matching holes on HS-810 and HS-814. Made the HS-00006 rib fit around HS-810 and HS-814. Prepared the HS-00005, HS-00006, HS-706, HS-707 and HS-708 ribs. Drilled the holes in the aft flange of HS-00006.
