21-16 step 2. Some how I missed the nutplates on the bottom skin around the access panels. Much harder to do now! Also decided to install nutplates on the antenna base. Found it easier to remove the two stiffeners above and below the antenna hole, then re-installed them. FUSELAGE KIT FINALLY FINISHED........WHHHOOOOHHOOOO!!
