Pulled blue plastic from inside surfaces of all winf skins. Found if you lift the plastic along one edge of the sheet, then tape that plastic edge to a broomstick. You can then use vise grips as a crank handle and roll it off. Found that when you slit along the broom handle with a knife, it was very easy to remove the plastic from the broom handle.
