JAMESs Web Site
VELOCITY- XLRG
Control System
11-28-2015
Trim base
I shaped some foam for the base an sanded everything up and did the 2 bid lay-up to hold in place
Again the bid will only lay down on rounded edges so that was the prep that needed to be done.
WOW 2,000 hours into the kit now!!!! I hope I'm over 1/2 way
Base in place
Trim plate next to fit up
VELOCITY- XLRG Home
2528
Brakes
Bulkheads
Canard/Elevator
49
122
Control System
Doors/Windows
78
192
Electrical/Instrumen
Engine/Propeller
141
432
Fairings
Filling to priming
155
533
Final Assembly/Finis
407
194
Inspections
Instrument Panel
Kit Purchase/Conditi
Landing Gear/RG
Shop
Time away from build
Wheels/Axles
Wings/Winglets
