Brief Description: Made power bar for positive and negative.
This was fun to make. I drilled and taped the power bars for 10/32 and 8/38 screws for wires to connect too. I did some tig welding on the negative one and made some insulated brackets for the positive bar out of 3 triax lay-ups. I then ran the # 6 wire down the fuselage conduit to the power bars mounted on the avionics tray. I have electrical connectors to mount the wire to the bars for the 60 amps needed for the front end if everything’s running at the same time.
