Brief Description: Fit vertical back panel and anchor nuts
I used the cardboard template to see how far off it was and surprisingly it only took a few cuts to make fit. I had to add in a few spots so when it was traced out on the foam the needed spots were adjusted. I added were it was needed. When I was happy with the fit the epoxy was next, had to go down town for 1.5 hours so the resin was put into cold storage and when I got home the heat gun got it to flow again. The next thing was the anchor nuts they were drilled and riveted in place.
