JAMESs Web Site
Date:  10-19-2014
Number of Hours:  0.00
Manual Reference:  9.6.3
Brief Description:  Wing and strake front end
My new laser showed up from Amazon and it was time to make a better cut for the wing. I lined up with the top and bottom and it worked out better then the eye ball method.
I won’t to get as much done on the fuselage before I kick it out side under the truck shelter. I will be working on the wings and canard this winter with filling and sanding to primer.
I then sanded and cleaned up the front storage area on the strakes for my tie down straps, they should fit very well in this space
New laser for cutting off wing
Pilot side storage for tie downs
Co-Pilot side storage for tie downs
