I put on the top strake and measured up from the bottom strake flange to the top strake. I moved the measurements from the lower strake to the wheel well and cut. I only had 2 spots to sand and the gap worked out to 1/16-1/8. I mixed up some bondo and installed the blocks to hold in place when the top stake is lifted off.
