JAMESs Web Site
Date:  2-18-2014
Number of Hours:  2.50
Manual Reference:  9.4.2
Brief Description:  Cut and fit upper stake Pilot side
Bit by bit I cut and removed the side of the strake to get it close for the last cut and sanding. On both lower and upper I had to remove more at the back end to have it swing over to fit the wing. Once it was in the right spot I made a few cuts to fit the right width at the wing.
Marking block set at 3/4
Marking block set at 3/4"
Upper strake fitted
Upper strake fitted
Copyright © 2001-2018 Matronics. All Rights Reserved.
