Brief Description: Had to make room for alternator and made 4” tube
I hung the alternator and found it was hitting the bottom of the cowling so a hole for clearance was made and a cover was glassed up. The fuel fitting and alternator covers for the cut outs will be glassed into place when they are cured and trimmed to fit.
I also made the other 4” tube for the exhaust extension and will be removed from the paper tube when cured.
