JAMESs Web Site
Date:  3-20-2016
Number of Hours:  3.00
Manual Reference:  12.3.4
Brief Description:  Cut and fit plenum over cylinder heads
We life has taken building time away from the plane, but things need to get done. We got a newer vehicular unit for Cynthia and she is happy. Good by Toyota Rav 4 and hello Pontiac 2009 Vibe all wheel drive even I really like the vehicle.
Now back to building I traced out the paper template for the cylinder heads onto the glass that I had done a week ago and cut out to fit over the cylinder heads. I left extra for fitting and after the sections between the heads where fitted then the tops were next and there was lots of trips to the bench for sanding and filing. I am pleased with the way they turned out, the ends are next.
Small gap at top
Small gap at top
Pilot side fitted
Pilot side fitted
Co-Pilot side fitted
Copyright © 2001-2018 Matronics. All Rights Reserved.
