JAMESs Web Site
Date:  11-16-2012
Manual Reference:  5.2.2
Brief Description:  Door weather strip prep.
First I used a putty knife between the duct tape on the door insert to cut and pried away from the fuselage. Then I marked the TRYAX lip to 3/4" and started to cut with a hacksaw blade. There where a few spots were it was not straight and was heated with a heat gun and pushed into place with my glove and let cool. I was amazed at how easy it was to shape the glass into place. The glass was harder like it was tempered when cooled. I will trim to 5/8" when it is all cured and hard.
Off we went to the Campaign and Chocolate due at Christina Lake.
Door incert removed
Door incert removed
Cutting with hack saw blade
Cut to 3/4
Cut to 3/4" to be trimed later
Copyright © 2001-2018 Matronics. All Rights Reserved.
