Brief Description: Prime, sand , fill one more time
I sprayed 2 coats of K2 primer out yesterday and got the sanding done tonight. The winglets and canard is now ready for smooth prime and another blocking to level and defects.
I will mount the rudders and see if any other work needs to be done. The ailerons need matching to the wing in one spot and I will work on this over the next few days. If all goes good they will be going to the hanger of the winter.
The canard will be flipped and the bottoms filled and sanded and then mount the elevators.
