Brief Description: Prep for K2 primer and sprayed out 2 coats
Prep for K2 primer by sanding a few spots from last night and sprayed out 2 coats. There are a few pinholes that jumped out at me spraying the primer on and I will fill the next time I’m working on the plane. I let the fans run to clear out the bleed off of the solvents and after a snack I got back to working on the speed brake filling.
