JAMESs Web Site
Date:  4-26-2015
Number of Hours:  5.00
Manual Reference:  14.2
Brief Description:  Sand wings add micro. Sand speed brake & prime
The rite angel sanding to get the curve just right. I found that if you sand at this angel up and down and then an X in the opposite direction the curve is created and is straight in the longitudinal direction as well. If the air board is jumping then the high spots are sanding down.
I added micro to the spare area and will sand in next time I’m in the shop. (Co-Pilot wing)
The Speed brake got some loving too and a shot of primer to help out. There are some spots that will need bondo to finish up.
The right angel for sanding
Micro added
Micro added
Primer on speed brake
Copyright © 2001-2018 Matronics. All Rights Reserved.
