JAMESs Web Site
Date:  3-8-2015
Number of Hours:  5.00
Manual Reference:  14.2
Brief Description:  Taped windows and did bondo work
Last night after getting some sanding done I could not take it any more with the dust.
The weapon to use was the electric leaf blower, so I blew off the shelves with the air compressor at 40 psi and opened both garage doors and out went a cloud of shmag from the leaf blower of stuff that was just lying around. I live in a forested area so the cloud would not see by any one. I say, if you do this cleaning and others can see, do it at night. The shop came out very clean one more time.
Back to filling and sanding I shall go. More work on the doors and fuselage sides. 18 hours was up so I sanded the micro on the Pilot strake and now they look and feel the same. I’m now sanding all the fuselage to get ready for filling were needed and then primer will follow.
Sanding with 120 grit for filling
Working along side to side
Micro sanded to match other side
Copyright © 2001-2018 Matronics. All Rights Reserved.
