Brief Description: More sanding and primer on strakes Happy
I got the sanding done from yesterdays work and that was a few hours of work. I had a few more spots to bondo on the winglets before I spay on the primer sealer. I find that the primer sealer is hard and it stops me from dinging into the soft micro when sanding the bondo helping keep the wings and winglets more flat. Wow I got primer sealer on the strakes and now I can work on the small stuff that needs filling and feathering out. I find that with the white micro on white micro it’s really hard to see where the small areas need work so the primer will help here. I only spay one coat at a time and work out stuff from there. I’m trying to keep the weight down only using enough primer to do what needs to be done.
