Brief Description: Door locking rods and assembly.
I cleaned out the door locking rod receivers with a file from all the primer and paint from the build. It took a bit of time tweaking everything for the final assembly. I had to heat the one panel once removed with 500w lights to bend down with lined gloves so it would touch the window. Co-Pilot door is close to completion now and a few thing on the Pilot door.
Oh use RV silicon to glue the window moldings to the door.
