JAMESs Web Site
Date:  3-5-2019
Number of Hours:  1.00
Manual Reference:  14.2
Brief Description:  Pitot tube showed up and it will work perfectly
Wicks Aircraft supply had the aluminum the fits the Pitot tube perfectly and will now cut to length and install into the fuselage. Item number is SL20-85-4-T6 : Description 2.023x857x049,D6061. This is the fist time I have ordered from Wicks Aircraft and they have lots of good stuff. I will be back if needed.
I picked up this working 12 volts Pitot tube on eBay and the complete set up with mounting strut aluminum will be $210, this is a lot cheaper the a new $700 + one for sure. I will clean the end that shows heat ware and paint with high heat paint that I have for the wood stove.
It fits perfectly.
It fits perfectly.
