Brief Description: Time to make a box for the roll trim motor.
One more thing to do before the carpet goes in the plane. A box has to go over the roll time motor so carpet can go over it and hide it from damage. I cut some cardboard and glued together with the glue gun, duct tape was added and this time I waxed the duct tape to see it the fiber glass will release easier. My resin pump was stuck and hard to more and I had to pump a few time into small cups and put back into the tank. I should do this every 2 months to keep things moving but one more thing I seam to have no time for. The resin hardener had crystals and the heat gun was used to dissolve the hard crystals and flow out the resin. I tried to do one layer at a time and got frustrated trying to use the same plastic to do the wet out. I think I forgot how to do things. I should know to do all the 3 layers at once and just use heat to saturate the glass. Once cured it will go into place and flanges add to hold in place.
