Brief Description: Worked on cowling. Prime, sand and fill 4 bids on
It has been very busy around the house so I only got a few hours here and there on the plane. The cowling was primed and filled and sanded then primed again. The next thing to do was to add a 4 bid lay-up to hold the back cowling into place at the cooling outlets to align. The cowling was torqued so heat was applied with lights before I removed the clamp that was holding the top and bottom in alignment for the bid to cure. I trimmed and sanded the out let. Micro and primer to finish this area is the next thing to do to finish this part. Next will be the rudder cables.
