JAMESs Web Site
VELOCITY- XLRG
Bus bar for fire wall side.
It was time to work on the bus par for the engine area ground wile the glass is curing. I cut drilled and taped the bar then welded. Nut plats mounted to fire wall and bolted into place.
Connected to oil pan bolt.
Bus bar mounted to fire wall.
Nut plates holding into place.
VELOCITY- XLRG Home
2528
Brakes
Bulkheads
Canard/Elevator
49
122
Control System
Doors/Windows
78
192
Electrical/Instrumen
Engine/Propeller
141
432
Fairings
Filling to priming
155
533
Final Assembly/Finis
407
194
Inspections
Instrument Panel
Kit Purchase/Conditi
Landing Gear/RG
Shop
Time away from build
Wheels/Axles
Wings/Winglets
