JAMESs Web Site
Date:  3-26-2018
Number of Hours:  3.00
Manual Reference:  13.3.2
Brief Description:  Wired in jumper and charger wires from the out sid
I had to move the upper plug because the aileron cable is now in the way. I drilled micro and bid the hole. The old hole was filled in and is now ready for wiring after curing and paint added. The wires are now connected to the battery. I will be making up cables to take with me incase I need a jump or a charge.
Welder plugs to jump or charge
Connected to battery
Back side of plugs
Back side of plugs
