Brief Description: Finished defrost on glare shield.
In my area I like to fly in the winter months and the window fogs up on my Piper Cherokee before I get to the run up area, so I hope this will help keep the windows clear and add heat to the fuselage until I get heat from the oil cooler in the front.
Nut plates are used to hold heaters in place and are very solid. There should be room for every thing in the front as glass panels will be used and all the electronics are mounted on the tray and wires run back to the panels. I will be using one or two panels with the radio and transponder as add on. I won’t to keep very simple and have what is necessary to operator the plane safely.
