JAMESs Web Site
Date:  2-27-2018
Number of Hours:  3.00
Manual Reference:  15.2.6
Brief Description:  Defrost out lets for glare shield.
After installing the glare shield onto the instrument panel and positioned into place the defrost vents had to be angled back to flow air up the window and leaving more room behind the instrument panel. After cutting and fitting with foam I did a 1 bid lay-up with micro to form and shape needed. This will work great with the 12 volt heaters from China.
Top side of glare shield.
Bottom side of glare shield.
