Brief Description: Remove wing and move fuselage in shop.
I removed the bolts holding the wing with the wing table in place. I then moved everything in the shop out of the way for the wing to be in one bay and the fuselage to move around into the position. The wing was pushed to the door to go out to the hanger and it snowed 6” 15 CM so the plowing had to be done first.
