Brief Description: Wiring the overhead lights and switches in.
I mounted the vanity lights and found some switches and placed into the hole and found that they were not the right ones. I had gotten the switches for the overhead 3 years ago and in the right box I found the correct ones for the job. I used 90 degree ends so they will not hit the roof and they all have to face one way to go into the hole for mounting. I used a 12 volt charger to make sure the worked before pushing the switch up into its hole, one more thing off the list.
