Brief Description: Time to work on the rudder cables.
It is time to install the rudder cables and connect the ailerons to the cables. I need to install a stainless sheet at the end of the wing beside the engine to prevent heat damage to the foam. I made the template and will trace to the stainless for cutting. Once this is done I can get things going.
