Brief Description: I worked on the governor today.
I got a reply from MT – Propeller USA to my questions. Peter Marshall General Manager answered my questions and even tolled me more them I asked. Great service!! I was told to remove the safety wire for the screws and rotate the arm to the position that would work for my application and re- safety wire the screws. Peter also told me how to adjust once the engine is running, good to know. Thanks Peter!!!
I finished the mounting bracket for the cable. I found that the wide washer jammed on the ball joint and the holes drilled were not in the right spot. Oh Shit I had to remove and tig weld the holes closed and re-drilled. I had to add small washers to move the big washer away from the ball joint arm and it all works great now.
