Brief Description: Mounted throttle and mixture cables.
Well on the mixture side of the bracket I had the down arm set for the wrong direction. I had to cut off with the cut disk grind down level and make a new arm to weld on and now it works as it should. I also had the angle for the throttle not right so I plug welded the aluminum and re-drilled with the throttle arm in the middle position so the up and down movement is equal in both directions.
