JAMESs Web Site
Date:  2-26-2017
Number of Hours:  4.00
Manual Reference:  12.2.1
Brief Description:  More fuel line work on plane
The return line to the tank had 3/16” clearance from the gear leg in the retracted action so I treaded the tank more and now the clearance is ½” and I feel better about that. I ran more lines from the boost pump regulator and this is almost done. The fuel out from the mechanical pump was made but some how I missed ordering the fire shielded. More stuff coming from Aircraft Spruce.
Return line to header tank
Compressed air help slide heat shield
More lines and looking good
