JAMESs Web Site
Date:  2-15-2017
Manual Reference:  12.2.1
Brief Description:  Ran more fuel lines.
I ran more fuel lines today and tried to install a hose fitting with no luck. I will have to replace the fitting as the treads cross treaded. That’s how it goes when your not an AME with a full shop of tools and knowledge.
Up date, I fixed the fitting and will be using it on the hose. I’m getting things figured out on the hose fittings. I spent a lot of time on the fuel system figuring things out but will not log the time. More parts have been ordered so this should complete the fuel system.
We builders need more web sites and up todate instalation information. I hope my site helps others
Tee with oneway valve
Line to fuel pump
Line to fuel pump
