JAMESs Web Site
Date:  1-24-2017
Number of Hours:  6.00
Manual Reference:  15.2.7
Brief Description:  Glass vertical sides and load brace for luggage sh
I made foam vertical side panels from the template and modified some to make fit, things must be going right because both sides are identical to each other witch is good. I then made 2 mounting brackets for the back of the luggage shelf and when done I mixed up resin and covered the peaces I made that day. I will clean up tomorrow.
Ready for glassing up
Curing time now
Curing time now
Tig welded bracket for shelf
Copyright © 2001-2017 Matronics. All Rights Reserved.
