Brief Description: Glass vertical sides and load brace for luggage sh
I made foam vertical side panels from the template and modified some to make fit, things must be going right because both sides are identical to each other witch is good. I then made 2 mounting brackets for the back of the luggage shelf and when done I mixed up resin and covered the peaces I made that day. I will clean up tomorrow.
