JAMESs Web Site
Date:  10-13-2016
Number of Hours:  6.00
Manual Reference:  7.7.3
Brief Description:  Brackets for main gear doors
It was time to work on the brackets that hold the gear doors at the spindle end of the gear. I bent to fit and had to weld on some aluminum extensions to make it all work. I’m glad I picked up the tig welder that can weld aluminum.
The nut plates were added to the doors for the spindle brackets and I got the bracket from the main gear to the door on the pilot side done as well tonight.
Pilot side door
Pilot side door
Co-Pilot side door
Co-Pilot side door
Attached to main gear
