Brief Description: Worked on plenum opening for air flow
Today was a good day on the plane. I sanded the bottom gear legs so the aluminum booties will fit nicely for the wheel spindles. The carbon fiber cloth is really hard to sand it is very tough stuff. Then is was time to spray primer sealer on the legs and just a few spots to fill for the next priming.
The resin had set up enough now on the plenum to work on trimming the cloth with the knife. I then cut out the inside with the air hack saw and cleaned up with the dermal tool and finished with a file. It is ready for glass work now.
