Brief Description: Worked on intake to air box (plenum)
I got to work on the runners from the NACA outlet and bondoed in place until it was removed for glass work. The ends or joint area will have to be rounded to mach the NACA outlets. I will do this when all the bid work is done and the inside is cut out for the airflow. I still have 25+ hours to finish this part of the engine cooling plenum system.
