JAMESs Web Site
Date:  1-14-2016
Number of Hours:  5.00
Manual Reference:  6.8.2
Brief Description:  Holding hinges for Dog house were installed
I had to use 3 different 1/8” drilling systems for this job 55 degree drill, drill bits with a shank for a socket to go onto and a home made drill bit. The home made one was shortened on both ends and a nut hammered onto the shank end for turning with a socket. In the 1st picture it shows the set up for the hardest ones to do. It was a very slow job drilling by hand to get started before a drill was attached and this went very slow also.
Flox was mixed into T88 structural adhesive and the sanded areas got a good spread for resin and then they were riveted on. I will work on an anchor system to hold the hinge pin next. A small amount of micro will be used to flow the fuselage into the dog house and vise versa.
Wow not easy drilling here
Canard hinge floxed, riveted on
Dog house hinges, flox riveted
Copyright © 2001-2018 Matronics. All Rights Reserved.
