Brief Description: Sand NACA funnels and make template for firewall s
I started the night looking for my lost wallet and no luck so the new cards are on there way. I headed for the shop to get something done and the Youtube music mix from my phone got me motivated for 3 hours tonight. I sanded up the NACA funnels and cut one to the same height as the other they will do for now and will work on them after the stainless in on the fire wall. Speaking of firewall I use the cardboard that the new washer and dryer came in as a template. I traced out on the out side of the fuselage and it was just about perfect for the right size when cut. I used a hack saw to cut the cardboard and sanded with 50 grit to take the shape needed. Just a few modifications will be needed on the ducts and tubing for fuel and oil cooler lines.
