JAMESs Web Site
Date:  1-9-2016
Manual Reference:  14.2
Brief Description:  More sanding and priming on the plane and panel
I got some primer ready (Smooth Prime) and sprayed onto the elevator, panel, and door strakes. The applications were 20 minutes between coats and the tip off the gun had to be cleaned each coat because the primer would dry.
This worked out nice
Primered up after sanding
Primer is finally on
