After the primer had dried I got the panel in the plane and looked on the internet for pictures to see if others had done the cut out for the throttle, pitch and idle cut off cables on the left side. I think I will just leave it all in one peace because I may not have to take it out to often over the years once done. I need that drill I ordered to finish the tight spaced ones on the bottom. I can work on the glare shield any way and the molding that goes on the side.
