JAMESs Web Site
Date:  12-25-2015
Manual Reference:  6.8.2
Brief Description:  One bid on elevator end and dog house bottom
The elevators were not perfectly matched from one side to the other as to the distance from the fuselage so I added some foam and bided the 3 sides and it should look better now.
I am very happy with the way the dog house turned out. I will only have to add 1/16 filler to the bottom corners to blend with the fuselage. I added one bid to the bottom and will let set over night and trim tomorrow.
The dog house will be mounted using hinges with a removable rod this way no screws will be seen.
I will have to add a small amount of filler along the dog house to fuselage in places so the gap is 1/16 on both sides for primer and paint. I will also add at the center of the fuselage so the dog house does not sag.
Elevator end has been added too
One bid on dog house bottom
One more time for this job
Copyright © 2001-2017 Matronics. All Rights Reserved.
