Brief Description: Finish blocking and spray 4 coats of smooth prime
I finished blocking out the K2 primer and found a few spots that needed filling so Spot-Lite bondo came to the rescue and it was ready for Smooth prime in no time. I mixed up the can of pre thinned Smooth prime and spayed out a tack coat and every 15 minutes another coat went on until the gun was empty and that was 4 coats.
It is so nice to have the filling and sanding done on the plane. Just small jobs on the filling and sanding now to get ready for paint.
I had some extra time between coats so I glued in the elevator bushings with T88 and flox. I used a screw to pull the bushings into place. I cleaned the area up with acetone when I was done and will let cure over night.
