Brief Description: Cut out winglet bottom for rudder and add micro
It was time to cut the winglet bottom for the rudders to fit in. Lots of cut and try then sand to get close. I see that the transition will need work and foam will have to be glued on and then shaped. The good side is that I got time in on the plane. Wedding, Fall Fair, Snow Plow, all got attention this weekend as well.
