JAMESs Web Site
Date:  9-20-2015
Number of Hours:  3.00
Manual Reference:  2.9.2
Brief Description:  Cut out winglet bottom for rudder and add micro
It was time to cut the winglet bottom for the rudders to fit in. Lots of cut and try then sand to get close. I see that the transition will need work and foam will have to be glued on and then shaped. The good side is that I got time in on the plane. Wedding, Fall Fair, Snow Plow, all got attention this weekend as well.
Winglet cut for rudder
All fits good Clearance has to be done
Alpha poxy micro added
Copyright © 2001-2017 Matronics. All Rights Reserved.
