JAMESs Web Site
Date:  9-12-2015
Manual Reference:  2.9.2
Brief Description:  Working on winglet bottom
I stared by blocking out the winglet bottoms to have them straight for attaching. I marked where they are to go and then added ¾ for the one bid to go into place once milled fiber is used to glue on. I see there will be some special work to have this attached with smooth transitions. I will be adding ribs on the inside as well.
Filler ground off
Filler ground off
Getting ready for attachment
This is what it should be
Copyright © 2001-2018 Matronics. All Rights Reserved.
