JAMESs Web Site
Date:  8-1-2015
Number of Hours:  4.00
Manual Reference:  2.6.7
Brief Description:  Aileron fitting and installed the nut plates on hi
I finally got some time at the end of the day to work on the plane. I had fitting to do on the Co-Pilot aileron after that was done then it was time to install the nut plates on the hinges. I did one nut plate on each hinges first, and then I did the others after screwing the aileron on.
The hinge pins were shortened and the ends of the hinges center punched to collapse the end a small amount so the pin will never come out in flight.
Spring keeper pliers help hold nut plate
Set up to center punch hinge end
Aileron is on !!!! happy me
Copyright © 2001-2017 Matronics. All Rights Reserved.
