JAMESs Web Site
Date:  6-19-2015
Manual Reference:  2.8.1
Brief Description:  Sanded rudder wells and added were needed
I had to sand one more rudder so I got that done and moved onto adding some glass to the rudders were they were cut to short. Easy stuff to fix and bondo will hold in place while the 3 bid lay-ups cure on the inside rudder wells.
I have filling and sanding to do on the rudders when the glass work is done. Things just take time.
Added glass were needed
Sanded and ready for glass
End needs to be sealed
Copyright © 2001-2018 Matronics. All Rights Reserved.
