JAMESs Web Site
Date:  5-28-2015
Number of Hours:  3.00
Manual Reference:  2.7.4
Brief Description:  Aileron construction & counterweights
I sanded up the glass that was cut long on the aileron wells and will sand the bottom when I go to mount the ailerons. There always seems to be a good side and a not so good side were thing did not go perfect and will require a bit more work.
I will get some expanding foam from the hardware store and fill in the areas that need it.
I mixed up some construction resin and added flox and micro balloons to the glass that the counterweight goes onto. I then added micro to the side of the weight and foam to hold the rod in place as well.
Well glass sanded
Well glass sanded
The good side and weight
Not so good side. Work needed
