JAMESs Web Site
Date:  5-5-2015
Number of Hours:  3.00
Manual Reference:  14.2
Brief Description:  Sand and add Spot-Lite bondo
The aluminum block with 80 grit was put to work tonight working on a smooth straight transition. I used the brush to wipe away the sanding dust and not blowing off the wing as the dust is too much to handle. On my second Spot-Lite bondo application I changed the hardener color and this will help me with defining dept and edge blending. A few more rounds and the K2 primer will be used.
Bondo sanded with block
Bondo added to wing
Bondo added to wing
New color and new bondo
Copyright © 2001-2018 Matronics. All Rights Reserved.
